Seany
New User
I have a 6 volt system on 601 selectospeed, it has been negative ground for as long as i have owned it, and worked fine...i began a restore, and wanted to get everything working on it, and thats when i discovered a problem.....the new fuel gauge is marked as positive ground. Is my tractor supposed to be positive ground, and if so do i only need to repolarize my charging system, or do i need to change out generator and regulator?
all pre 64 gassers were 6v + ground.
ALL diesels were 12v - ground.
all 65+ were - ground.
to swap polarity, change battery wireing, repolarize generator.
this assumes you have no odd custom solid state parts ( no 6v -gr ei, no 6v neg grnd alternator..e tc. etc.. )
(quoted from post at 14:59:33 10/04/14) all pre 64 gassers were 6v + ground.
Thanks for ur response, will try tomorrow.....will let u know!
All working well now. Thanks for your help.
