The parts diagrams for the Squealer models is here:
http://www.bushhog.com/uploads/documents/BHRotaryCuttersq36-sq84oldPM-03.pdf
The tail wheel assembly for the SQ84 is in diagram number 23-4-3. It looks like it could have a single piece wheel (third picture in that diagram) or a two piece wheel with replaceable tread (first picture in the diagram).
Check the diagrams to see exactly which parts you need and then start calling salvage yards. If you tell us where you're located someone here might be close by and know of some local salvage yards you could try.
If you do a Google search in the individual part numbers, the new replacement wheel halves for the two piece wheels aren't that bad:
Wheel half for two piece wheel - $21.19 at Madison Tractor Company
Unfortunately, the one piece wheel assembly doesn't appear to be available unless it has been superseded by a different part number, as all of the Google hits on that one say "Call Us". If you have the one piece type, it probably wouldn't hurt to call one or two places to see if there's a newer part number and how much it would be.
Or you could check Tractor Supply to see if one of their generic ones might fit.
It is the one in the Bush Hog Parts Manual labeled tail wheel
for SQ84, assembly 95342, Caster wheel assembly P/N
50058327. I am looking for a used one.
Maybe someone on here knows of a good salvage yard near you, but we won't know that unless you tell us where you're located.
