How does this work?
gunny2
I mounted this remote and only have up pressure. When i pull lever back it raises,when i push forward it floats down ,no down pressure. I thought by mounting both lines i would have up and down pressure? What am i doing wrong? Thanks Don
remove the plug next to the first outlet and install the other fitting and outlet, so that you have a two way cyl action, not a one way.. push only. The second hose connects to the other side of the cyl for the PULL action.
You need to connect the other port to the opposite end of the cylinder.
The valve is convertible. Most likely you will also need to convert the valve to DA mode.
Dean
Where did you connect the other end of the second line from the cylinder? Only one port on the valve has a connector on it in your picture. If you already connected the other line from the cylinder to the other port in the valve that has the square headed plug in your picture, then you probably also need to change the valve from single acting mode to double acting mode, which I think is done via the flat headed screw on the right side of your picture, just above the pivot point for the control handle. I'm not sure if you need to turn that screw clockwise or counter-clockwise though.
Sean i think your onto something as i have limited
knowledge of this. Maybe someone will know if the
screw needs clockwise or counter to activate double
acting mode
