1710 leaking fluid , coming out by shifter boot ??
dave404
1710 leaking fluid , coming up by the right shifter boot ??
I figure the whole plate will need to be removed. So what part will I need to repair this ?
I also need to replace both shifter boots. are both the same part # ?
diagram doesn"t show anything that would keep oil from coming up around gear stick, unless I missed something.
would the boot itself serve as a seal ??
or is there a seal underneath the plate ?
First thing I'd check is the oil level. Usually when they start puking oil out the top it's because they're full to the lid with water.
Rod
