I have a Ford Loader Backhoe:
Numbers stamped on the Bell housing above the starter are:
FF311S
1J08B
*C673302*
It has 750 on the backhoe. I was told by a New Holland Parts guy that the Model # FF311S meant it was a 755.
The problem I'm having with it is the system relief valve n the loader section is bypassing oil. I took it apart and it looks like some of the o rings are damaged. New Holland is absolutely of no help. Cain't get the valve or the o ring kit. Their parts catalog does show a break down of the valve with all the parts. Some of the o rings have specs. But they don't match anything I have found at o-ring suppliers. Ford's specs are in thousandths of an inch where those available from stores are in increments of 1/16th inch. I need very badly to fix this valve or find a replacement. Any help or advice will be appreciated.
Wally Smith
FF311S
1J08B
*C673302*
Wally Smith
