What Model Tractor Is This?
velonaut
New User
I know it's from 1958 to 1962, it has a diesel motor, 4 speed trans, PTO, no power steering.
Offhand looks like a 641D or 841D. Look on the flat spot on top of the left side of the transmission under the battery and see if you can spot some numbers. May have to scratch through some blue paint.
It's either a 641D with a 144 cu in engine or an 841D with a 172 cu in engine or possibly a mutt which is a tractor built out of a lot of parts. If you post the engineering number that is cast into the right side of the engine block we can tell you which engine it has. The 801 series has a larger rear end than a 601 series. Post a photo of the upper link mounting lug on the rear end and we can tell you which one it is.
There is only the D for diesel left. the rest is corroded away. I have tried doing a tracing but no luck. It is completely corroded away. It has CONN 6015 F cast on the right side of the engine, 312476 on the left side of the hyd. case. Any other bits of info I can provide?
Looks to be a hybrid. 8 series hood, 6 series rear wheels/tires, cannot determine size of engine from photo, *4* transmission.
Need photos of rear of tractor for more info.
Dean
I want to thank everyone for your help so far. I need to determine what the displacement is of the diesel engine, the oil pressure is low and I may need new bearings, oil pump, or who knows what to get it right. I'm trying to repair this tractor on the cheap since money is very tight.
