1710 hydraulic pump o-ring fit ??
dave404
this is my neighbors 1710 and it keeps blowing the o-ring at the coupling that goes to the valve underneath.
we think the wrong one has been used. im not familiar with the 1710, so can someone tell me if it uses a single o-ring or a spacer and o-ring or ???
It is a common problem with a loader, the frame bolts that go into the engine work loose and the frame moves up and down letting the oring come out of the pump and blow out, if the frame bolts are good you can slot the holes in the valve mounting plate and push the tube in the pump more so the oring does not get near the edge.
thanks scott, so I need to chk the frame bolts to see if theyre tight. I noticed the movement up and down while raising the bucket.
