I volunteer at a civil war farm near
Gettysburg, PA. I do maintenance. Recently they
purchased a Ford 600 series 5 speed to do bush
hog work. I cannot determine what size engine
is in this tractor. It may be an industrial
since there is a plate bolted over the fuel
pump opening. I do not think it is a 134 cu
inch because it has a TSX62 carb which has a
2&11/16 inch bolt spacing. I know it is not the
correct carb but it works. The manifolds all
look original to the engine. Would a 172 cu
inch engine bolt up? Can it be identified if I
get pictures?
get pictures?
