6610 II - Power beyond or third remote?
Hello,
Recently purchased a 6610 series II with a factory cab and loader. The loader currently uses the 2 remotes on the tractor.
What are the options for adding a power beyond adapter and joystick for the loader? Sorry I'm used to IH terms so not sure if Ford called them Power beyond or not.
Another option would be to add a 3rd remote. I'm assuming that I would need to find a scrapped tractor to get the parts for the 3rd remote.
Let me know what the available options are.
Thanks.
there is a set of factory 10 series remotes on ebay Now.. for $500
Or you can get the power beyond blocks.. and plumb in a cross valve and pioneer fittings. Which will still run you $300 by the time you buy most of the parts. The power beyond plates are probably a limit production run and soon will be sold out, if I am reading the market correctly..
Basically, your options are used remotes or an
aftermarket ccls control valve. I believe bern
posted some info last week on a gresen v20LS that
he has used in the past for exactly what you
describe. The plate that billis talking about... I
am 99% certain will NOT fit unless you want to
live without the access hatch in the cab floor for
the rest of your days...
So basically you get the gresen valve mentioned, a
tee for the remote supply and return lines and a
shuttle check tee for the load sense line... The
mount your valve where you please.
Rod
(quoted from post at 09:18:16 09/26/14) Basically, your options are used remotes or an
Rod
Thanks. I will have to investigate this option. I have little experience with a closed center hydraulic system so this information very helpful.
