getting a few things done on the NAA. needs lots. pretty hard to get it into gear, most of the it grinds. once in a while goes into gear. all the adjustment is gone on the pedal. pedal will not go to the floor but gets solid. do i need a new clutch, or is it still sticking at times? thanks for any info.
Might be 2 issues, wet oily sticky clutch, and worn, out of adjustment. Warning, if no free play, you will have ton wearing fingers
(quoted from post at 14:11:45 09/26/14) Might be 2 issues, wet oily sticky clutch, and worn, out of adjustment. Warning, if no free play, you will have ton wearing fingers
so does that mean i pretty much got to split the tractor to investigate?
