Ford wheel adapter info needed
NNP
I'm going to put a want ad up,
and start scrounging yards to see if I can find a set
of those Ford rear wheel adapters that go from little 8 to big 8 lug pattern.
need them for a project I'm working on.
Were they on LCG Fords originally?
Part number?
The more info I can put in the ad and searches will help.
Thanks.
Here is a pic of a set on a Jubilee.
I have a set here. Don't know what they are worth.
Maybe the fellows here can help us determine a fair
value. Sent you an email.
The only place I have ever seen them is on early
3000s with spin outs.
(quoted from post at 05:56:12 09/24/14) I'm going to put a want ad up,
Part number?
Thanks.
Talked with UD and his are a bit different and he knows positively what they are/were on.
So, I am still curious if anyone has seen this style?
Just an inch or 2 thick with holes for the small stock lugs,
and studs for the bigger pattern. Like aftermarket car adapters.
When I had them, I looked them over very closely and they didn't look homemade.
Possible of course, but they must have had a CNC machine or been very talented...
I've seen the style used on the early 3000s but I've never seen the type pictured.
Aftermarket?
Home Made?
Dean
(quoted from post at 08:12:57 09/25/14) I've seen the style used on the early 3000s but I've never seen the type pictured.
Aftermarket?
Home Made?
Dean
Thanks Dean, I was hoping you'd see the post.
If none of you guys that worked there have seen them.......home-brewed, and I can stop looking.
For those who may be interested here is kind of a poor photo of the wheel adapters I have on this parts tractor here.
If and when I get these off I will take some better photos of them.
