when i adjusted the valve lash on the 3600 they were very loose, .050 plus gaps on them.
i was wondering, it was apparently running this way for a while, none of the valves looked bent, etc.
could running it this way for a long period of time cause something else to wear causing a small knock in the engine?
i cracked each line for the injectors to cause each cylinder to stop firing, and the knock was present at all times. i"m guessing piston slap, or perhaps "all" of the injectors are bad.
