Pull the cover off the regulator. If the points are stuck together, that is where your short is located.
Is this a original 6 volt + ground tractor??
If so + side coil to distributor
- side coil to keyed power (power only with key on)
Suppose to hook to a terminal block under the dash but many have been just hooked to the key switch over the years as terminal blocks went bad and were never replaced.
