horhay
New User
I replaced my broken pto shaft and now the pto shaft will not dis-engage. he pto shaft does run my mower. Can someone help
are you saying you annot move the pto lever.. or it moves and makes no change.
post back
if it moves and makes no change, make sur ehte handle is turning the rod. if it is, pull cover and make sure the shifter mechanism is actually engaging
This post you say the PTO will not dis-engage
Your last post you said the PTO will not engage
The post before that you found chunks of the housing when you replaced a broken PTO shaft.
1) You will most likely need to take the top off the hyd section to find out where these broken pieces came from.
2) Start over and Confirm what problems you are really having.
