3000 ford hyd oil
cole in mo.
Pulled the brake, clutch shaft out of a blue 3000, the oil that came out looked like something drained from under the engine of a rumley. What is the proper hyd oil for this tractor?
a 3000 uses a common hyds/rear end sump. UTF fluid meeting the M2c134 spec is suitable for the shared hyds/diffy. also fine for the tranny. also fine for the power steering..e tc.
MANY generic UTF's to choose from. depending on your area, you migth avoid some of the 19$ per 5g kinds as they can be stiff in cold weather, but would otherwise be ok.
do not use r/o and plain hyd / jack oils.
