1967 Ford 2000 diesel battery
Bart CA
What are the specs for the battery (amps/hour). Previous owner installed a truck type big battery pack which is cracked and leaks. I wd like to replace the battery with one with original specs. I had a service manual with the tractor but no infos on the battery other than it is 12 volt.
Thanks in advance.
Bart
BCI group 4DLT. The New Holland battery part # F150DSW is 1000CCA. TSC and NAPA sell a 4DLT (at least in this area) that is 820 CCA.
DO NOT GET A 4D!!!! But do get a 4 dlt... completly different battery. One will fit and one will NOT fit.
Many thanks Soundguy
I measured the actual battery and compared to 4DLT
exactly the same dimentions. Bough a new one this morning starts like a champ !
Thanks again
Bart
2110 LCG is the same tractor as the 3 cylinder 2000, except the front axle spindles and rear wheels were shorter, so yes, it will take the same 4DLT battery.
