toolgarage
3 Point was working fine. Using a brush hog to cut a field. After about an hour of use, the 3 point wouldn't raise. I'm waiting for my service manual. Any ideas on what to look at first?
Thanks.
Thanks.
(quoted from post at 08:01:49 09/23/14) Thanks Sean.
Is this the one?
(quoted from post at 08:04:28 09/23/14) Sean,
Was this the correct plug for the rear end level check?
Thanks!
ttps://forumphotos.yesterdaystractors.com/photos/mvphoto11553.png[/img](quoted from post at 16:32:10 09/19/14) Check the fluid level first.
Then bleed the pump.
Let us know your results.
(quoted from post at 07:40:14 09/29/14) The plug should be the only one on the pump with a recessed hex head that would accept a large allen wrench. it should be on the outboard side of the pump, just below the center line, opposite from where the lines going to the rear end are connected to the pump.
(reply to post at 17:10:09 09/29/14)
