Ford 3600 rewiring Part 3
Ok I was able to ohm out and get everything wired BUT the idiot light for the charging system. When I turn the key on (without starting) I should get 2 red lights: oil and charging- right? I have the oil light but need to figure out the alternator light. What do I wire the bulb ground to that will give a ground at start and remove same when charging?
