4400 horizontal exhaust pipe
Ultradog MN
Location
Twin Cities
I'm about ready to switch the exhaust on this tractor from vertical to horizontal but I'm not sure which exhaust pipe I need to buy.
Based on the fact that the intake side - air cleaner and tube to the manifold - is 2 1/4" I suppose the exhaust pipe would be 2 1/4" as well?
I'm finding part # 82009286 for a 4000 but gosh it's $187 compared to a 2" one for a 3000 is under $60.
I might be willing to spring for the $187 if I knew it's the right one but Messicks doesn't give much info on it.
Can someone shed some light on it? Is #82009286 2 1/4"? Is it the whole pipe from the manifold to under the axle (less muffler) like the 3000 one?
Mark B or Mark (mhb@ufe)?
Thanks to any and all.
I sell the less expensive one for the 2000 & 3000 for the 4000/4000SU tractors. Nobody complains.
Nobody wants to hear about $187 for that pipe.
Thanks Rick,
I didn't want to hear about it either.
What about the tractor breathing right though?
The volume of a 2" tube is roughly 40% smaller than a 2 1/4" - 3.14 square inch vs 4.9 - if I did my arithmetec right.
Just wondering
(quoted from post at 22:11:50 09/17/14) I'm about ready to switch the exhaust on this tractor from vertical to horizontal but I'm not sure which exhaust pipe I need to buy.
I bought the muffler that I wanted. Loaded the tractor on the trailer and went to an exhaust pipe shop. Boy there bent and installed one for me. $20 take him about 15 minutes.
Thanks.
Been thinking about that route myself. I'm only about a mile from a Midas.
Run the tractor up there with the vertical muffler then change the manifold in the parking lot.
Like I said, nobody complains. If it didn't work, I'd probably have guys throwing those pipes through the door at me.
A custom pipe is always an option if you have concerns about the flow characteristics of the smaller pipe.
