Ford 6610 hydraulic flow
David G
I have a 6610 with dual pumps, and want to size the loader valve correctly. What is the flow rate, and what size loader valve should I get?
Thanks
I think Rod answered this in a post from a couple weeks ago. Working to many days erased my memory.
I am planning on a 15-20 GPM valve, please let me know if that is wrong.
I am posting a picture of my supply tie in, I will work on shuttle and sense next.
Rod is correct, you want a 20GPM valve. I used a Gresen V20 load-sensing valve when I did it. Worked very well.
Your tee fitting looks good.
The switch has been intermittent for 10 years, I will wait till spring to do it. I need to replace hoses on PS cooler and convert loader to CCLS, that is enough to bite off before snow time.
