AlanBarrett
[b:d7b62208f9][u:d7b62208f9]Back story:[/b:d7b62208f9][/u:d7b62208f9]
Got a 3600 that needed rebuilding/rewiring. Got the engine rebuilt. Started on rewiring. Only existing wires were starter and alternator wires going to external regulator and key switch. The tractor had a fire years earlier and subsequently was rigged up. No wires going to gauges. I purchases a new gauge cluster and wiring harness from this site. I did not buy any wiring for headlights or rear light.
[b:d7b62208f9]AT THIS TIME I DON'T HAVE AN OEM LIGHT SWITCH[/b:d7b62208f9]
I have ohmed out and got the starter, key switch, and alternator wired. At least as how it was wired when I got the tractor. The tractor at least will crank up now.
Attached are pictures of the gauge cluster, alternator, and back of gauge cluster. If anyone could comment on the questions I would appreciate it.
[b:d7b62208f9]NEW CLUSTER[/b:d7b62208f9]
[b:d7b62208f9]BACKSIDE OF KEY SWITCH[/b:d7b62208f9]
[b:d7b62208f9]A[/b:d7b62208f9]-runs to the big 12V wire on starter (that runs from the battery).
[b:d7b62208f9]C[/b:d7b62208f9]-runs to starter solenoid.
[b:d7b62208f9]Does anything else run to the other pins?[/b:d7b62208f9]
[b:d7b62208f9]A[/b:d7b62208f9]-Single wire from tank sending unit runs here.
[b:d7b62208f9]B[/b:d7b62208f9]- Single wire runs from temperature sending unit to here?
[b:d7b62208f9]C[/b:d7b62208f9]- I do not know
[b:d7b62208f9]D[/b:d7b62208f9]- I do not know
[b:d7b62208f9]E[/b:d7b62208f9]- I do not know
[b:d7b62208f9]J[/b:d7b62208f9]- I do not know
[b:d7b62208f9]E[/b:d7b62208f9]- Does anything connect to this pin?
