New member here,I have spent sometime on this site but never had to post a question. I will say there is an unlimited amount of info. and knowledge here. With that being said i want to thank everyone in advance that is involved with this site.Tractor info>
Tractor #C760978
Mod. #LA414C
Unit #6E6E
Engine #6D9A
Trans. #6D09B
Rear axel #5M10B
Hyd. pump #6D2B
Hyd. lift #6C14B
I picked up " what i think is a 1986 " Ford 5610 ll at a sale, to use as a second tractor on the farm. Tractor is sound,solid and runs out very good. I am somewhat familiar with the 1000 series but have no experience with the 10 series. The tractor has had remote valves in the past by the hose connections off valve under seat. I need to add at least one remote valve to this tractor. New Holland prices are out of MY world. Seen a 5610 somewhere that pressure line came off valve under seat to double aftermarket valves with return back to top of rear housing,dont remember where i seen it. If this is possible,enough pressure,volume,heating issue,etc.?? This tractor does have the metal hyd. lines that run to cooler in front of radiator. I dont have to have all parts OEM, but like everything in its place and out of the way. Sorry about the long post,just trying to give all info.I do have a repair manual in route. Need help on this . I will post pictures soon. Thanks
Tractor #C760978
Mod. #LA414C
Unit #6E6E
Engine #6D9A
Trans. #6D09B
Rear axel #5M10B
Hyd. pump #6D2B
Hyd. lift #6C14B
