Wiring 12 volt gauge?
gunny2
In the process of converting to 12 volt, want to replace the amp gauge with volt,if i connect one wire from volt gauge to the terminal block and where does the other wire go ? Thanks Don
One wire to switched output, other to ground. Match battery polarity.
If you connect it before the switch it will run continually, even when tractor is off.
wire the wires that went to the ammeter together ( post type ).. or if loop, just rmeove.
wire one sid eof gauge to switched side of key, the other to chassis. observe polarity.
