Indiana_Hoe
New User
Hi, I have a 68 4500 TLB. Its "new to me" when I got it i was told that the power steering didnt work and that it maybe needed fluid. I have the integrated hydraulic pump with no reservoir. At first it didnt work at all but i was able to muscle it around the yard. Decided to look into it today and got all the gunk cleaned out from around it and got it to turn right. Not left. When the drag bar is moved (Right hand Turn) it pushes it forward which moves the linkage backwards and pulls out on the actuator. This makes it turn right. I understand everything up until now... When you turn left it wants to push the actuator (on the hydraulic PS pump) in....its already retracted and " bottomed out" from where i turned right.. Where is it supposes to go??? How does it make it go the other way when the actuator is already all the way in... basically you have to muscle the assembly..
