Hi folks.My 971 select-o-speed w/a 1 arm loader needs fluid change. A past owner has put pipe fittings and hydraulic hose from the transmission fill port back and under to the hydraulic drain port, my assumption is to increase volume of oil for the hydraulic system .!?
I bought some high dollar oil for the transmission Valvoline 318 , an equivalent of the M2C41 ford specifies but calls for M4864A or B for hydraulic.
I need a filter for the transmission , if anyone knows of a source please Lmk.
I'm thinking the extra plumbing was for fluid volume for the loader. I could be wrong.
Does the 1 arm loader need all that volume to work ? This loader does not have a 2nd cylinder BTW.
I believe that this tractor was ordered with this loader, only 1 headlight ( r side ) and no indications it ever had a light on the left side.
Also , this tractor has the optional 4 wheel front end.
All opinions are appreciated.
