1967 Ford 2000 Starting problem
Michadav
New User
I'm having a problem starting this tractor. There was no lead up to the problem. It just quit starting. I have ruled out the starter and replaced the solenoid. Also, I have checked the ground. When I try to start it, I get a clicking/buzzing from the solenoid. Not sure what to try next. Any help would be appreciated.
is it a twin stick model with NSS ( range lever in neutral to start? )
If so, jiggle the stick, or hold key in start and run the stick back and forth thru N a few times.
the switch is marginal.
also always need to check connections at battery and cables and ends... and for this type of start system.. checking the start wire to the solenoid from the key ( thru the NSS )
