Will the rear end from an 8n bolt on to a jubilee?
If not can the axles be removed from the 8n rear end and installed in the jubilee rear end? TIA
8n4235c is the currently supplied 8n axle
8n4235c also happens to be the NAA axle
rear ends are not compatible. way different hyds setup, not to mention pto shaft.. etc.. etc..
