jubileeguy
I just converted from a 6 volt positive ground to a 12 volt negative ground and everything went very well and the tractor starts and runs better than it ever did. However now the starter motor is not behaving. When I hit the starter button the motor winds out but does not engage. I can get it to engage eventually by giving it short bursts at the stater button. It will take several attempts and then it will engage.I will take any advice on my next steps to pursue with this.My research prior to installing the 12 volt system was you do not have to replace the starter from the 6 volt system. It did not do this before the conversion so perhaps the change has damaged it in some way. Thank you in advance for sharing your knowledge with me.
