1963 Ford 4000 PS leak
Abbby
I have a 1963 Ford 4000 (4 cylinder) rowcrop with a PS leak. This one has a belt driven pump with the PS cylinder built into the steering arm that runs from the column to the front. The leak is on the cylinder at one of the joints. Are these failry simple to take apart and fix? Looks like three bolts to take it apart.
Not sure where your leak is.
It is a simple job to replace the cylinder shaft seal but futile if the shaft is rusted. Seal kit available from CNH.
Dean
