Ford 3600 Injection Pump Settings
sixbales
Howdy guys (and gals),
I received an email today requesting data plate information from the injection pump on my 3600. The problem is that my 3600 has a 201 engine, and I doubt that this same info will apply to a 175 engine? Here is what the man requested:
"My fuel injection pump was leaking through the throttle arm and I was attempting to put in new seals but when I took the top off, the governor spring fell out before I could see where it goes. The pump must have been replaced in the past because there are no settings code listed on the tag on the pump. That code provides the setting for the spring. Could you please look at the tag on your pump and give me the setting code you have?
Not sure if all 3600"s are the same but it should give me a starting point. Otherwise there are 9 different combinations I will have to try."
Any help would be appreciated.
Some Ford DPA pumps do not list the setting code on the tag like most Perkins did. Card file shows 3 3600 pumps listed, 3233F631 is code 5, middle hole at each end. 3233F880 and 3238F100 are both code 9, bottom hole in the governor arm and the closest hole to the shaft swivel point. If you have a different pump list the complete # so it can be looked up.
Dieseltech
Sixbales posted this for me and I am just now getting back to this pump. I have it all cleaned and new gaskets put in place ready to reinstall on the tractor. I appreciate all of the assistance from you and sixbales. The number on this pump does not match the ones you posted. i got the tractor second hand so do not know its history. The numbers on the pump are as follows.
DPA 323315
Mod Blank
Set Blank
Ser 31633ZM
It is a CAV pump Made in England
Any further information would be most appreciated.
