I picked up the 72 for a project to sell. Now I have a problem. The 72 has the high low range trans which I like much better that the 63. The 63 is in much better shape cosmetically and runs smoother as it is a 4cyl. The sheet metal can be fixed and time is not an issue ( retirement is grand). The 72 runs fine and needs small item fixed such as gas gauge, temp gauge and leaking seal on steering box. The 63 needs nothing. Only issue is the lift cylinder leaks slowly. It takes about two days for it to drop. Before I put one up for sale is there something else I should be looking at to help decide?
Thanks
Des
Thanks
Des
