I just change the seal on my PTO shaft. Of course being a newbie with this whole tractor thing, I pulled the shaft cover off and out came all the fluid. I got every thing back together without too much trouble. I put new fluid in the fill port just below the seat and now when I pull the dip stick out to check the fluid the case is so full it runs out the dip stick hole. Should I drain some of this out and pour it into the after most fill port? Or will it equalize into both compartments when I run the tractor?
I have not run the tractor yet as I have to get the broken goose neck off to install the new muffler, and that is being a real challenge without removing the intake/exhaust manifold off as the bolts are extremely rusted.
Thanks any help the group can offer!
