Help Ford 1700 Deisel Tractor
My hydraulic system quit. It will not lift the plow. I cleaned the filter and changed the fluid. It still does not work. What do I check next? Could it be the pump or something else. I need suggestions for toubleshooting?
You need to buy a service manual. If you are going to troubleshoot tractor hydraulics you need gauges and specifications. There are too many possibilities to start guessing.
