The last few months after use you could hear the cooling tank boiling and coolant whose very low. I replaced the radiator cap with a new 4psi cap and replaced the temp gage. I checked the system to 7psi and the cap to 4psi and they check good.
Today the radiator whose 1/2gl low after filling the temp rose to 210° in the first couple of minutes of run time and didn't fall. I shut it down at that point but the engine block whose quit hot and lower coolant hose whose hot all sow. The upper hose whose cold still. Dues it sound like a thermostat problem?
Anyone have a NAPA part number for the thermostat and gasket?
