TractorLinks.com
Show Parts for Model:
Re: Coil getting hot
Abbby
08-28-2014 18:58:18
OK. So rest of the story. 12 volt neg ground. Rebuilt the carb and it fired right up and ran for about 5 seconds and shut off. No spark at plugs or coil wire. I have an external resistor coil with resistor so hooked up. Now voltage at coil is about 4.5 on plus side and .6 on neg side of coil. still no spark. Is this the right voltage and do you think I smoked the resistor. I will take off cap tomorrow and make sure points are still opening.
JMOR
08-28-2014 20:15:03
 Re: Coil getting hot in reply to Abbby, 08-28-2014 18:58:18
4.5v.........is this right? You never did answer the question as to what is primary resistance of the coil, so no one can properly answer that question as to 4.5v or not. Voltage is the indirect way to arrive at an answer, anyway. What you are really looking for is a steady state primary current of 3.5 to 4amperes. Select resistor to obtain that amperage.
