Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 2000 Parts Online
Re: Ford 2000 coil
soundguy
08-25-2014 11:00:51
i'm gonna make a few guesses here since you decided not to provide full info.
1, this is a 4 cyl 2000
2, this is still a 6v setup
3, you are using a 6v round coil.
if all this is true.. unless you have a real odd coil.. it should not need a resistor.
how about throw us a bone and tell us WHAT COIL you have.
kurly
08-25-2014 12:26:36
 Re: Ford 2000 coil in reply to soundguy, 08-25-2014 11:00:51
Quoting Removed, click Modern View to seeYes this is a 1962 Ford 2000 4 cyl farm tractor, as I stated it is 6V(positive ground).The latest coil I installed is a 6v round Car Quest 26207 coil. The instructions state that this coil is for "use without a external resistor". The last coil was also for "use without a external resistor", but was a Tisco brand. I am knowledgeable about Ballast resistors in 12 v systems but never hear of a resistor in 6v system. Just wondering if something is wrong that the coil only lasted 1 month and started leaking oil from the top. Most likely Chinese junk. Thanks Kurly
soundguy
08-25-2014 12:36:58
 Re: Ford 2000 coil in reply to kurly, 08-25-2014 12:26:36
should be 6v coil.. probably junk if it leaked
kurly
08-25-2014 12:44:16
 Re: Ford 2000 coil in reply to soundguy, 08-25-2014 12:36:58
Quoting Removed, click Modern View to see It starts better than ever now so lets hope it keeps it up Thanks,
Kurly
soundguy
08-26-2014 04:46:06
 Re: Ford 2000 coil in reply to kurly, 08-25-2014 12:44:16
Good luck, keep us posted
