Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 3000 Parts Online
Re: Ford 3000 Drag link end - nut is stuck to stud
08-24-2014 13:14:52
Actually, your comments, thanks all, make me wonder if and or how bad this joint is, so I made two more videos.
The end is tightly in the drag link and I have read horror stories here about separating an end from a drag link.
First video(Just 44 seconds) full weight on front tires, second (37 secs) no weight on tires.
This post was edited by Johneich at 13:20:28 08/24/14 2 times.
08-24-2014 13:27:02
 Re: Ford 3000 Drag link end - nut is stuck to stud in reply to Johneich, 08-24-2014 13:14:52
I just watched your videos. The "side-to-side" movement you commented on in your first video and observed on both sides is NORMAL. However, the looseness in the RH end that you showed in your second video is NOT.
I'd like to see another video like you did with the second video, but this time, angle the camera so we can see the bottom nut. I can almost guarantee you that this nut is moving back and forth as well. The nut SHOULD move as one with the arm, locked down to it, not rock back and forth. Compare this with the LH side, it is NOT moving I'm sure.
I'm guessing that your ball joint is just fine, however you lost the taper fit between the stud and the arm, and now the hole in your steering arm is egged out.
