TractorLinks.com
Order Ford 3000 Parts Online
Re: Ford 3000 Drag link end - nut is stuck to stud
W Neal
08-24-2014 09:31:12
You need a "nut splitter", or if you can cut the nut with an angle grinder, being careful not to cut the tie rod end. Once the nut is off you need a fork shaped "tie rod end remover"like is used in automotive tie rod end removal; hammer it in between your tie rod end and the steering arm and it should "pop off". when you're set up & ready to drive the fork in, a bit of heat applied where you want it to "pop" will help. Since the tie rod end is already "turning" in the arm it must be somewhat loose and should come of easily.
Good luck!
