Thanks to u guys, no ether for 10 days straight!
jwjsr
4000 3 cyl diesel
Had been using ether about every 3rd starting attempt for 10 years. 10 years ago the local ford dealer said I needed a $1000 injector pump. I am happy to report they are no longer in biz.
Y'all were kind enough to guide me through fixing various leaks-Orings for throttle control and fuel shutoff shafts inside the injector pump, one injector leak around the cork seal etc, new batt cable to insure good high CCA's, adjusting valves, tank clean/drain., replacing solenoid after I busted the cap, sealing tranny cover to keep water out, replaced alternator I probably shorted out. New front wheel bearing etc.
Thanks again guys!!
Oops,I can't quite declare total victory yet as I haven't done a lot of hot restarts yet.
WJ
Hi
Glad you finally got the issues dealt with and she
stays good now. Looks like I can finally let the
lawyer go, was getting expensive having him on
permanent staff, "Just in case I got sued" L.O.L
Good luck and If your stuck again just ask on here.
Regards Robert
It's been so long I forgot to tell my lawyer to dismiss the suit. Maybe if y'all chip in and pay for the alternator and solenoid he will just forget it?
DOG was excluded from this case long ago , as he inadvertently gave my his phone#, and actually answered my calls.!!!
Thanks again, it was kinda fun seeing what u were doing in that cold part of the states when I bothered you.!!
