4000 3 cyl diesel
Had been using ether about every 3rd starting attempt for 10 years. 10 years ago the local ford dealer said I needed a $1000 injector pump. I am happy to report they are no longer in biz.
Y'all were kind enough to guide me through fixing various leaks-Orings for throttle control and fuel shutoff shafts inside the injector pump, one injector leak around the cork seal etc, new batt cable to insure good high CCA's, adjusting valves, tank clean/drain., replacing solenoid after I busted the cap, sealing tranny cover to keep water out, replaced alternator I probably shorted out. New front wheel bearing etc.
Thanks again guys!!
Oops,I can't quite declare total victory yet as I haven't done a lot of hot restarts yet.
WJ
Thanks again guys!!
WJ
