Got the 3600 oil pressure checked today, cold it was 67 lbs, about 60lbs warmed up. got the oil sensor light to work finally as well- rat chewed the wire. i am going thru the new machine trying to get things tuned up.
I have driven a few 3600s/3000s/4600s the last couple of months shopping for the one i finally bought. I noticed the engines are fairly loud, all of them. not only general noise level, but they all seem to have a type of what sounds like compression knock or something? I am use to hearing my small 3 cyl dexta which is very quiet compared to these bigger 3 cyl"s.
How do you know if the knock is just normal or not?
also
I will be adjusting the valves this weekend, I usually spray my valve cover gasket with high tack and stick it to the cover when replacing. Is it a good idea to use the tacky spray or not?
also
