I am getting ready to sell my Ford 860. For the last year I have chased an overheating problem/stalling problem and finally got it straightened out. Recently I was shredding on a hot day and all went well for a couple of hours. Engine started to falter and lose power, acting like it was operating on only two or three cylinders. If I gave it gas, it would come out of it in a minute or two and run ok for 10-15 minutes and then falter again. After the 4th or 5th time it got real rough, backfired and stalled a few minutes later. I let it cool down, tried to restart it with no success. I towed it out of the field. I am just getting around to dealing with it and find no problems with carburetor adjustments (I rebuilt it 150 hours ago), airflow through air filter (oil bath), fuel flow, etc. Compression is down to 100 lbs in all 4 cylinders (from 120 last time I checked 180 hours ago) leading me to believe that the problem is with the valves (heads and valves done 180 hours ago) or leak in manifold. Does that sound reasonable or should I be looking at some other alternatives? I need to get it running well to sell it but if repairs too costly I will need to sell "as is" for a lot less.
