OK, worked a few hours on her today. got the hood loose assembled back on the chassie.
fenders and grill and egg crate are done, but still inside the shop.. ran out of daylight, plus i want to repalce the bolts on the fenders. the old ones had to be busted off.
rims were painted last week. i wanted to get them back on as i don't like her on all jack stands and cribbing as long as the horses and cws are inthe pasture. all i need is for one to knock that heavy thing off.
i put an old set of rims on the front for painting purposes. rears are the correct ones and installed now.
i was torn on the air breather tube. mine is 3 pieces, piece from box to clamp on hood, a few inch riser, ad then another riser with mushroom cap.
I decided the lower piece coud be chassis color and the top 2 above the tin could be grey.
steering wheel is not done, still filling in a couple spots with bondo, but it is installed with acorn nut on finger tight .
got battery installed, most of the
seat not done yet, nor have i installed small parts like shifter handle, etc.
wireing back on, and the alternator....
completely ran out of light... had to take pic in the dark.
