NAA 3 point
fredmich
Earlier post of mine I complained about the tractor able to lift a 8" dearborn disc but not a 2 bottom dearborn plow. Well after closer examination yesterday, my problem seems to be the arms are not going up high enough. The pins between the 2 implements are at different hights which allows the one to clear the ground and not the other. How do you adjust the arms to go up more with the quadrant controll all the way up? They definitly don't look as if they go as high as my 8N. Thanks....Fred
I didn't try that yesterday and the tractor is 100 miles away but I did try both positions when I was trying to move the plow. The lift is not slow it just don't go very high and the pins on the plow are mounted high on the plow. Could the quadrant be out of sync? Fred
All of the adjustments are done by removing the lift cover and yes it could be an adjustment or worn parts. It doesn't by any chance have extensions on the lift links that were used with the old rear mount mowers does it?
Mark
No, I think they are the standard ones.. Any threads or pictures that would guide me to pulling the cover and adjusting? I did my 8N lift last year with the Zang fixture and it works good. I know they are a different system but with some guidance or advice I am willing to give it a shot..Thanks...Fred
