Pie Weights
Are they the light set or the heavy set? 24 or 28 inch rim?
Heavy set for the 28 inch rim goes for about $500 here.
Others are more as they are harder to come by I guess.
Heavy so-called AG set.
Price is at the high end for complete set needing refinishing.
Segments will interfere with rails on PA rims, limiting adjustment range outward.
If you have never sandblasted, primed and properly painted a set of Ford pie weights before, be advised that it is an enormous amount of work.
Dean
Dean
Sounds good to me. keep in mind a set of mounting nuts will really do a job on a couple hundred dollar bills.
