Anonymous-0
Good Morning, I am having an issue with PTO on this tractor.
When you push clutch the PTO will not work - it just grinds - won't engage.
Then you have to shut tractor off - push PTO level to engage and it runs steady. The PTO will not shut off using the clutch.
Would you be able to tell me if there is an adjustment for PTO clutch to correct this?
