I have a 5200 with single hydraulic remote. I would like to
change this to a double remote so I can have capabilities to
use it with other equipment. Could someone point me in the
proper direction to find the necessary parts?
If I remember right, those rowcrops use a different valve than the utilities. You may need to start calling boneyards. Or... one of those 'multipliers' may work for you. They plug into your existing remote couplers, and have 2 pair of couplers on them . An electric switch controls which set of couplers gets flow when you move the tractor's remote lever.
Yeah I had though about an electric multiplier, however I would much rather have original with live power to both all the time. I was hoping someone may know of a bone yard that may have something.
Try All States Ag Parts or Worthington Ag Parts. Pretty sure I've seen a 5200 on the web site for one or the other. Thinking it was probably Worthington.
The valve body castings are different between single and double spool, so you would need to get a complete double spool valve. You can't simply "add" another single spool to an existing single spool and call it a double.
