541 engine replacement
I bought a 541 with rod through the block. I
found a replacement block with the following numbers: EAE6015D under that number are these:
3352. Now the rebuilder wants to know the specs.
and year on this engine. I know nothing. Can someone
help. Thanks in advance.
EAE indicates a 134 cu in block built from 1953-1957. I don't know why he needs the exact year because all of those 134's are the same but if you look over on the left side of the block near the rear corner you will find a casting date code which consists of a numeral and 2 letters. The numeral is the last digit in the year- 195 3,4,5,6 or 7.
