Anonymous-0
Greetings all -
Last winter, I requested help from you on my 4th gear popping out of gear under a moderate load. Many came back that the spring that holds the ball in place is probably at fault.
WayneIA indicated a bolt on the right side of the transmission hides the spring & ball.
I checked last night, and it could be one of several locations.
Could/would someone photograph that area and indicate which bolt is the correct one to look into ?
Thanks !
Pete
Thanks !
Pete
