01 Series Front Loader
Scott_65020
New User
I have what I believe is an 01 series front loader. I'm curious if there is a way to put a hoe attachment onto this tractor. It is not a pto tractor, its a straight up front loader with a giant concrete block on the back....
They made a few different loaders for the '01 series tractors. If it has no PTO, the tractor itself might possibly be an 1801 Industrial model, which would make it more likely that the loader frame was designed to also be a subframe for a backhoe, but then you would have to find the correct model backhoe to add to it.
Post some pictures of what you have and someone here will probably recognize what it is and be able to answer your questions better. Or, if you can find the ID plate on the loader frame and post the number here, it would tell us exactly what loader it is. The ID number would likely be in the form of I9-xxx, where the numbers in the place of the "xxx" would tell us the exact model
how about you throw us a bone and tel us what tractor you have!
tell us what type of hoe you are mounting.
maybee even post up some pics.
It is Likely possible to mount up a hoe and laoder depending on types. many times 3pt hoes can be added and tied in via subframe to an existing loader frame for strength
